Technical  Trip computer problem
gsch89
I have a 2009 Bravo and lately the button at the end of the stalk for the trip computer does not work when I press it to flick through the info. I have also noticed the Mode button on the dashboard doesn't work either to change the time / date. It makes a beep when pressed but nothing happens on the display. The display works fine and correctly shows the mileage and time as it should but the settings are frozen. I have been quoted £60 for a diagnostics check just to see what the issue is... Any similar problems or solutions out there? Thanks!
Hi maybe is an error in the system(software), you can try to disconnect the battery for 15mn and see if the reset clears the error.
Belated thanks hakiro09 for the suggestion - I have just tried disconnecting the battery for 10-15 mins and the menu button now works. The trip computer is still not flicking between the different options when I press the button at the end of the indicator stalk. It literally stopped working from one day to the next! Any other suggestions?
