We had yellow warning light on dash of 2015 panda , checked every bulb which we’re fine , apart from BRAKE light bulb which was the problem , new bulb all back to normal now
If you watch the digital display when you start the engine (and the triangle illuminates) you will see a check lights message; this disappears quite quickly so just leaves the stressful triangle warning
And, if your phone is trying to connect to Bluetooth as the car starts, those warning messages tend to be hidden by the name of your phone provider flashing up in their place.
The bulb check system is ‘odd’ as some lights you’d expect it to be ‘watching’ aren’t checked. The indicators aren’t (because you know when one fails as they flash twice as fast - but that’s not the case if the side repeater fails). It doesn’t check the headlights as it assumes you can see a fault there. It does check the side and tail, also daytime running, number plate and rear fogs lights. But not the reverse light.
