- Joined
- Oct 26, 2005
- Messages
- 359
- Points
- 132
After getting a new front lower suspension arm fitted to my Punto I took it to have the tracking checked and adjusted. However they couldn't free the locking nut (pictured below). They put the blow torch on it but no good, said they could try fitting a new track rod end, though it might need the inner one as well.
Wondering about tackling the job myself. I have the Haynes manual but it only covers the basics of removing the track rod end (splitting the ball joint, counting the number of turns to undo the end, etc). I've looked at similar posts but not found very much about the inner rod so would value any advice/hints/tips. In particular:
Is it worth trying to replace just the track rod end? If so what would be the best way to separate this from the inner rod?
Would it be easier to replace the inner and outer parts together? If so how do you detach the inner rod from the steering rack -- the joint (picture below) doesn't seem to have any flats to put a spanner (or crow's foot) on. Also, I gather it is likely to have threadlocker applied - how difficult will that make it to unscrew - has anyone done this?
Thanks!
Thanks!
