General towing hitch
aberaeron
does any one have a pic or info on my proplem ,i went to fit an original fiat marea towing hitch know when its up and bolted to chassie the exhaust hanger on the back box wont fit:bang: as the tow hitch was secound hand is there something missing ,as in a new rear exhaust mount if so does any one know were i can get one or do you have a pic so i may be able to fabricate one out of some metal:D
I had the same problem but I cured it by bending the bracket I have a pic when I sort it out I will post it (think I did put it on here at the time)
The towbar in the link Ry put on isnt a Fiat original Fiat used Elibi.
https://www.fiatforum.com/marea/86707-exhaust-bracket.html
found it remember what I did now the brackets too wide so I cut it sort of off centre cut a piece off then drilled a hole in the piece I cut off then if you put one hole on top of the other you have the same shaped bracket but not as wide
well,well thats a great idea will have a go tomorrow,you dont half have to make big holes to fit spacer's thou :eek: now i have yet another little problem the miles/trip has fadded it come on but so dim you can barely see it does it have a bulb to light it up or is it more sinister:bang:
