bhinderharminder
My alarm (Ai606) went of on my car today, after i turned the alarm off, i put the key in the ignition and the led flashed orange 3 times, dose anyone know what this sequence means.
samburdett said:will beep 4 time if a sensor has been set off (next time you open it), the led will then flash a number of times to indicate which sensor has been set off.
2 flashes of the LED is the aux output (the one without pre-warn) so i.e. the glass break sensor.
Its something like that anyways.
has it happened alot or just the once, if its happened once forget about it, if its happened alot then maybe begin to worry, also did u have it professional installed?
