Phiz
Alright folks, any pointers on the following wold be greatly appreciated
I've started dealing with the rust in the seam between inner wheel arch and boot floor and basically 2 sections ahve completely rusted through, with the bit between being rusty but generally solid.
I cut the back section out and have started making patches to weld in. Once I properly cleaned the steel ready to weld the first patch in I noticed there was a small rust hole in the next section along (the one I previousl described as generally solid:bang
see pics.
https://goo.gl/photos/mifZbHfL16RoGMd39
First image is the section I have already cut out and started to replace
https://goo.gl/photos/TdGH6cV2QxKXDpbC7
Second image is the hole, it's right in by the seam and approx 1cm long...
Should I cut this next section out too, potentially filling it with weld, or treating it with kurust and seam sealing over it or is this just hiding a problem rather than dealing with it? Obviously I don't want to spend time on work that is not required, or replace metal that does not need replacing however I do want to make a proper job of it and I don't want to be heading back to weld up the same area in a couple of years time!
Any thoughts/opinions received gladly.
Thanks again
Phiz
Thanks again
Phiz
