Technical  Tipo can’t start
Tobias10
Denmark
I have a Fiat tipo from 2021, 1.0 petrol. It has an active error code u1701 8f. We have changed BCM, PCM, ESL, battery. but still can't turn on the ignition. Witech can't communicate with abs, pcm, eps. when I measure ohms at pin 6 and 14 in the obd connector I get 60 ohms. can anyone help with what it could be?
Model
Tipo
2021
Mileage
42000
Witech says the key is enabled correctly. And the key less start contact is replaced
Sorry I haven't got a clue, all I could find is, possible ABS computer? :(
"U1701 means a primary vehicle computer, usually the Engine Control Module (ECM) or Anti-lock Brake (ABS) Module, has stopped communicating. Your car's modules constantly share information over a network called the CAN bus. This code sets when a module goes silent and stops broadcasting expected messages."
Hi.
I had it looked at again. And they found that it was the steering column control box that was defective. It is in the series connection to the ABS and engine control. Which explains why it gives an error on either the engine ecu or the abs ecu.
