General  Tipo 2020 Hatchback trunk dimensions??
Trubkin
I'm planning to switch from my Bravo 2 2007 to Tipo, thing is, I don't know if Tipo has similar dimensions as Bravo. I need to fit stroller inside and neither my dealer has Tipo in stock. I know that Tipo has like 30 liters bigger trunk, but raw dimensions would be better. Could any of you folks help me and measure it? I need depth, width(especially on upper part) and height. Thanks!
2017 5 door hatch, RHD, parcel shelf in.
101cm wide side carpet to side carpet.
81cm lower seat back to boot lip trim trunk depth depth at trunk floor level.
61cm height to parcel shelf bottom.
the rear seats lean back slightly so the depth will reduce slightly the further up the trunk you go but not by too much.
the width stays almost constant all the way up to where the parcel shelf sits and from front of trunk to back
  • Like
Reactions: ben
