Technical Tipo 1.4 easy dash cam hardwire
Wazoman
Hi can anyone help with hardwiring a mirror dash cam, it's already fitted using cigarette lighter point. Just need help with the best fuse points to tap into for positive always on and in with ignition for the hardwire thanks
Thanks what did you use for the always on power to supply the parking mode for the dashcam
Ok no worries thanks for the window fuse heads up, will see if anyone else will jump on for the other 👍
Try this the hard wire version works well with nextbase hard wire kit.
after dismantling the light in the headliner, you have a hidden harness (blue-white wire if I remember correctly) in which +12 appears when you turn the key.
