From memory, as it's 10 years since I last did a 1.8 Stilo, there are no marks on the cam gears, but there is something for the crank. The recommended method is to use 'cam' locks. However when I did mine I marked the cams and crank as the engine was running fine, and simply ensured that the new belt matched the existing (my) marks.
Usually the inlet cam will spin 90deg as soon as the belt tension is relieved, so it needs holding in place while the new belt is fitted. In reality it's not a difficult job to do, and access is the biggest problem. But, if you're not mechanically that savvy, it could go very wrong.
Are there any 'YouTube's' for using the kit ?
