hi mrfit ,at what cost was your belt done? if you dont mind me asking
I have had problems with timing belt before if your not sure when it was last done GET it done.If it fails it will cost alot more don't take a chance I did cost me 1200 to sorti'm not 100% on the price but i'm pretty sure it was around £100 - £130
also had my lower crank pully changed at a later date (12,000 miles later). If i'd know about the rubber spacer perishing on them i may have had the pully changed the same time.
the crank pully cost me £115
Part was £80 and £35 labour, it's only an hr job to change the pully so not really a big issue to have them changed at seperate times as i did 12,000 miles driving out of it
its the lower crank pulley that the fan belt goes round, i got 80tho out of mine , i think the rubber perishes , its a bit like a cush drive on a motorbike rear wheelHi Misfit
Welshspark here. Dude I had my timing belt and auxilary/fan belt (got both done at same time)replaced a couple of months ago on my 04 plate at 50000 miles as the fiat manual said 72000 or 5 years which ever came first, the 5 years old bit was first in my case.
But Im more interested in the bit about the rubber spacer and crank pulley, (is that the wheel the auxilary or fan belt runs on ?) Ive done 58000 from new now, should I be replacing mine yet or can I go to 80000 or so,?? what milage did you get yours replaced?
Cheers for any input mate.
