Hi All,
I think my little 2003 MPI Seicento is due for a big service, my reasoning behind this is as follows.
I got the car in November 2011 with 54,500 miles on her, currently she is now on 87,400 (yes that some mileage in 2 years). In this time I have done the following.
I also replaced a rear brake cylinder as this had seized.
General Servicing;- Oil, Oil Filters (every 8-12 months) Spark Plugs (Every 6-8 months General NGK plugs) and replaced air filter and HT leads with the first service I done. I have also had 2 sets of brake pads on the front and replaced the rear brake shoes.
I have also had the clutch changed around 63,000 miles as it was snapping cables for a past time (4 in the space of 2,500 miles)
I've had the radiator changed as this was leaking.
The car does a mix of town driving, national dual carriageway driving, motorway driving and helps move houses a few times a year.
Is there anything I should be looking at / checking / doing extra now the car is starting to get to a higher mileage?
I'm due to do an oil change as its around that time I've already done the plugs the weekend I'm looking at HT Leads again (as have a missfire on idle again).
What's involved with a big Service?
Currently I have uneven pad wear on the driver side front brake and its slightly holding.... is this an easy fix?.
Any help / suggestion please?
Many Thanks
Martyn
Many Thanks
Martyn
