Technical  Threaded/Stripped a head bolt
Huwjones55
I'm looking to replace a head gasket and managed to stripped one of the bolts.
Any tips?
1) Plusgas / PB Blaster?
2) Bolt remover tool like this:
Irwin Bolt Grip Nut Remover
Tried vice grips, but that didn't work
I don't want to use heat with all the oil etc
Welcome to the forum!
When you say stripped a bolt, do you mean rounded the head? If so some Irwin removal bits should do the trick. if you mean you've stripped the thread then your in big trouble.
You might be lucky and be able to get a 6 sided socket still onto it, might take a light hammering to get it on.
Could also try the size down or an imperial socket and try and hammer it on, both things have worked for me in the past on old or already rounded bolts i've come across.
Hope he gets that sorted OK....
Anyhoo, more info for my impending gasket swap, a good quality 13mm
1/2" drive 6 sided socket on the shopping list...(Snap On ?)
Just to be even more paranoid, do the old head bolts ever snap whilst getting
them out?
Guess that would be curtains for the block....:eek:
Exhaust manifold studs look a bit vulnerable as well....told you I was paranoid
The head studs will come out OK as a rule -- often they'll still be attached to the nuts, so it's just a case of soak in a light oil, use the 2 nut trick to get the nut off, and clean up. If they do pull the thread out of the aluminium head, it can be helicoiled (but I've yet to encounter it on these).
Never known a head bolt to snap.
Just about any 6 sided socket will do just fine. Trick is to use a breaker bar initially, one hand on the "working" end of the bar, one hand on the socket end, holding it down and in place. After undoing them all half a turn you can reach for the ratchet.
Not sure if this is along the right lines but couldn't you just use what we call an easy out or a turnex tool? As we work on planes and the bolts can get their heads rounded, you just drill into the bolt head and use a left hand threaded easy out which then acts as a new bolt head to unscrew the bolt
I suppose of the bolt is hardened then you could aways try a Cobalt or some sort of carbide drill
Jack
Result, I'm pleased to say all the bolts came off.
Thanks for all the help.
Bought a 13mm hex socket which worked on all but one bolt.
For the last one I hammered on a 12mm 1/2 hex socket and managed to undo it
Relief all round !!
I live in Hertfordshire, does anyone know we're I can get the head cylinder skimmed?
