Fuel consumption on my 2006 Panda 1.2 dynamic seems high, 40 mpg max sometimes just under. I would expect 50 mpg.
Workshop told me it's all set in the ECU and it cant be tweaked. why so high?
I never go above 70 mph except by mistake. air cleaner okFuel economy in the panda is very dependent on average length of journey and driving style.
So, three questions:
- how long have you owned the car?
- what is the average length of your journey?
- how hard are you driving it?
and we'll take it from there.
see above &Fuel consumption on my 2006 Panda 1.2 dynamic seems high, 40 mpg max sometimes just under. I would expect 50 mpg.
Check tyres and pressures. Brakes for dragging/ binding
OK thanks. as it happens the engine light does not come on. I'll see if the garage can check for binding on brakes. It idles smoothly. Last MPG test ; 7 litres in 64 miles (roughly gallon and half)Fuel consumption is determined by the ECU, but it is doing what it does in response to the inputs it gets.
It will keep trying to adjust the fuelling when something is not quite right, until it gets to the point where it can't adjust any further. It will then ask for help (by putting the management light (EML) on).
However, just because it hasn't lit up the EML doesn't mean it is running well.
Even if it shows no stored errors, I suggest you should check for:
Tyre problems (low pressures, knackered sidewalls)
binding brakes
Ignition problems (plugs, leads, etc.)
Fuel problems (try putting a bottle of injector cleaner in a tank of petrol)
Surprised you find it to be a heavy car... It should roll easily on a reasonably level surface, so if it doesn't I suspect brakes or tyres may not be quite right.
Ok. So that's the solution-pensioner style driving! I'm having the brakes checked for any binding. Are the newer (2012 onwards) models any better? I do know the more recent 500 is good on fuel..7 litres in 64 miles equates to 41.56 mpg.
I'm not yet convinced there's anything wrong with it. Most faults which could impact economy will put the EML on. A dirty air filter will have no effect whatsoever on closed loop fuel economy; the ECU will adjust the fuelling to compensate.
40-45mpg is typical of a 1.2 Panda/500 when driven in the usual way at the posted speed limits.
Fuel economy is very dependent on journey length and driving style. The 1.2 is capable of averaging a real-world 60mpg, but you'll have to drive very carefully to achieve this, keeping below 55mph & treating the brake pedal as a control for emergency use only. Running the A/C in hot weather will easily knock 10mpg off the best achievable figure.
Next time you're driving on a dry, level motorway, put the trip computer into average mpg mode, then once you're established in the cruise, reset it, continue for 30 miles or so at a steady 50mph, and post the trip mpg you get. I'd expect to see a figure well into the 70's.
Tyres and oil grade will also make more of a difference than you might think.
I have found my panda 1.2 eleganza to be great on fuel. Even on particular weeks where the car only does short trips.
I followed your advice JRKITCHING on replacing both o2 (lambda) sensors and found the car idles much better and drives so much smoother! Plus the car idles properly, rather than all over the place. As a result, my MPG has improved too!
Matt.
