My '94 Punto 90 (pre CODE system) came with a third party immobiliser when I bought it, I wasn't a particular fan of it but it seems to work, until now :bang:
I have no idea why, worked last time I started the car (about a week ago) but now nothing!
It works with a fob that you put in a little slot in the dash, it beeps and then you can remove the fob and start the car, if you don't put the fob in it'll let you switch the ignition on but when you turn the key to the start position nothing happens, it seems to work by interrupting the connection to the starter I'm assuming
Anyway, today it decided not to work
I put my fob in, it beeps, turn key in ignition and it acts as if I haven't used the fob, no response from the starter.
Unfortunately I have no documentation of this immobiliser so I don't know where to start. I was pulling off random pieces of dash today working my way back from the fob slot in the dash etc.
It comes down from the fob into the O/S fusebox area just down to the right of the steering column, there are several black wires which splice into other wires in that area, those wires also lead up to the ignition barrel but only splices into 1 wire there, from there it goes down and into the centre console area.
This is where I need some input, in the centre console behind the ashtray etc i have a black box with lots of black wires going into it (so far all the wiring that comes from the immob fob slot is black), this also appears to be where the 'beep ' comes from when I put the fob in. Its sat very snug in there however and I can't really see how its attached but it won't budge, can anyone confirm this is not standard in a Punto?
Thanks....
Thanks....
