Technical  think i messed up
ontheroad
Hi all. I've been getting banging from my outside front and after a bit of research and inspection found out it's my strut top bearing/mount. Now I've ordered the strut top bearing but after looking again think it's mounts I need too lol. Is it worth changing the bearing if the mounts gone? Also is it dangerous to drove with mounts like this?
You might as well do both the bearing and top mount..
Do yourself a favour and get some industrial release spray and keep spraying those nuts on top..
Also u will need 3 or 4spring compressors..I couldn't compress the spring enough with 2
Hi
I've done these on my frog (along with many other jobs) and replaced both the bearing and the metal and rubber triangular block. To get either of these off, you need to remove the shock from the car, and the spring from the shock, so I would do both to avoid repeating this in a few months.
I found that the easiest thing was to take the shock off the car, go to a local mechanic, in grubby clothes for a better price, and ask them to remove the spring from the shock, and rebuild it with the new parts. I think I paid £20 per side, which although is spending money on DIY tasks, having not to venture into spring compressors is well worth it. The spring is about 50% longer when it is off the car, which is a hell of a long way to compress the spring with those spring compressors. I've nearly lost a digit on 2 separate occasions and I now realize that I need them!
I hope that this is of some use.
Hi
Thanks for the replys think I'm going save my moneys up buy correctl parts then get a garage or someone who knows what they are doing do it for me lol. Can anyone tell me if the cars safe to drive as it us fir the moment cheers
