The Speedtest thread.
bludvl_x19
42 Wallaby Way Sydney
Château Verdafluer
Ok, I have notced that there seem to be a lot of people posting their speedtest.net results so I thought I'd make a thread just for them.
First I did it with my closest server:
Slow. but that's what I'm paying for.
And having seen the outrageous speeds you guys have, I thought I'd go the other way and try to go slow hte slowest I could.
Not much difference eh?
Michael
See Sig - but that is on my rented server, not my home ISP.
Home is showing this, on VM 20Mbit:
Pretty poor on an 8MB product and living less than 2 miles from the Exchange but better than the 480kbps d/l and 256kbps u/l that I was getting a couple of months ago until BT didn't fix a fault that wasn't on my line. ;)
Mine are too. :p Can see them from my bedroom window. :)
Morecambe hasn't moved into the 21st century yet. :rolleyes:
Should post your stats up really to see if there is any problems on the line. :chin:
Type you routers IP address in your browser, log in and look for a button called "Show Statistics" it will open a pop up up window, copy and paste all the data it show up into a post. :)
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 80572 80544 0 903 1558 10:11:05
LAN 100M/Full 83649 84147 0 1616 968 10:11:37
WLAN 11M/54M 1089 0 0 6 0 10:11:23
ADSL Link Downstream Upstream
Connection Speed 4000 kbps 448 kbps
Line Attenuation 50.5 db 27.0 db
Noise Margin 6.1 db 20.0 db
Your attenuation shows you are pretty far from the exchange. But, you are getting a good connection. (y)
My only concern is your noise margin, it's low, should be high at this time of night. :chin: Could be a router bug though. To stop drop outs it should be at least 7.
You should consider a new faceplate and sort out your cabling a bit to boost your connection a bit, but you won't see massive imporvments due to you being quite a distance from the exchange. :)
