Kwick Fit
Need i say more?
Posted a few months ago about this rattling, it was anoying and didnt really make much difference. The rattle sounded like the exuast and was only there at low Rpm - idle or lower and only when the engine was under strain. so moving off from just the clutch, it you Drove it normally it was there but only untill engine stopped shaking the exsuast.
Now though, after once again someone else drove my car. . .
the rattle is ALOT louder and has become more violent and banging - again sounds like its from the exsaust middle section near the CAT - which was replaced by the evil works of the Kwick Fit garage
Only big difference between befor and now - besides the change in sound - is that this happens at idle while the engine is NOT under strain. i.e not in gear just turned on :bang:
There is also now clear damage to a sheild by the CAT showing signs of being hit Billions of times in the same place by a brackets that Kwick Fit fitted with the New CAT
Has anyone else had similar problems? Just the exsaust or something worse?
Need i say more?
