Technical the rad fan operates at high speed only
Hamada
hi all
my rad fan just skips the normal low speed and only operates at the high speed.. and now i got the temp fixed at about 92 degrees (2 notches above the center point)
i checked the fuses and they were fine and changed thermostat and it didn't solve the problem
any theories?
On most models there is a resistor fitted on the back of the fan housing could well be one of the wires has rotted off or the resistor is duff.
thanks mate
i will check that resistor and report back
