The quick question thread
why, what one? its not that one where we didn't hear the lead pop on is it? could be needs new leads. dont normally get a duff plug in a set of ngk's normally only champion
not unloaded the bus yet
when im driving there is a lack of power and if i put my foot down usually between 2 and 3k revs the car starts hesitating and theres no power has done it above that though, also my mpg is between 23 and 24 :cry:
im not sure what plug or lead but i did take them off and pop them back on except the last one closest to the battery coz i couldn't get it off i might try again tomorrow
the IR LEDs in remote controls
are they just plain old IR leds that i can buy on eBay and the like?
I have an HDMI switch remote thats stopped working after being dropped :eek:
happened before and i swapped the LED for noe from an old Xbox 1 remote
Yeah, all IR LED's are pretty much the same. If you have another LED lying around you could connect in parallel to test - e.g. connect a red (visible!) led and you should see it flash. Alternatively point the remote at a camera / webcam and you should see it flash.
TBH I would be surprised if it's the LED - more likely a cracked track. Do the above point-at-a-webcam test while gently flexing the board to see if it comes back to life.
you know electrics just make sure you get a matching impedance n stuff. otherwise somthing may not work as well ro work too well
