The one and only code for fiat radio thread.
Hi, i need help to get my radio code. I have a Fiat punto Pop from 2014. My radio is a bosch, 815cm0387e1031426
Can you please help?
Thanks in advance!
Okay bro, I'll be here again on December 10th. Until then, I will use my Bluetooth speaker while driving my car :)
Tried the code afraid says ‘Radio blocked/wait’. But message not going. Tried turning engine off code request came back but same response. Any ideas?
Thanks in advance
How long it takes for that message to clear will depend on how many incorrect code have been entered, the ignition will need to stay on for the time indicated below
waiting-times-jpg.215910
Edit: I just re-read your post, if the code Davren has given is giving the blocked/wait message, then you've likely provided the wrong serial number, double check it and make sure it's correct.
Pretty sure codes correct but will recheck and get back
So I have photos of serial number and radio and the numbers I gave are both correct.
