The one and only code for fiat radio thread.
I have 2 x Panda 100hps. I put an aftermarket Sony unit in one of them. The other one I removed to disconnect its aftermarket bluetooth unit which was draining the battery. When I put it back in, it asked me for the code that I don't have. So I thought I'd try the unit from the first 100hp. It also asks for a code. A little dejected, I put them aside and thought I'd deal with it later.
Now that its later I realise I don't know which radio is which anymore and I need a code for both. Is that possible?
thanks
Jason
thanks
Jason
Post the serial numbers, not photographs.
Fiat PAnda 100hp
7 646 396 316
e1 034502
815 BP638686166649
Fiat Panda 100hp
7 646 314 316
e1 034501
815BP631465534460
Both are factory Blaupunkt units.
thanks
Jason
Hi, i have a Fiat Albea from 2004.
I have the original radio code (is written on a small plastic on my spare key). This code was ok in the past (i used it many other times) but i didn't used the car for allmost 2 years and i scrapped it because it was pretty damaged (clutch, body, etc).
Now i tred to use the radio with another Albea from 2005 (i have two btw), but the original code doesn't seem to work any more. It displays "WAIT" and after approx 10 mins asks for the code again. If i re-enter the same code, displays "WAIT" again and so on. The original code was 3456.
Can you pls help me with this?
Fiat Palio CC Clock
7 642 378 316
e1 021614
815 BP237844803645
Cristi
Fiat Palio CC Clock
7 642 378 316
e1 021614
815 BP237844803645
Cristi
3456 is not the correct code for the serial number you have posted.
I have the correct code for your serial number.
Click the link below while logged on to the forum from a computer, not a phone.
https://www.fiatforum.com/donations.php
Use the PayPal button on the left under "Make a donation.".... Do not use the button on the right under "Make an anonymous donation"
Hi guys,
Sorry to bother you all but I’m converting a Fiat Ducato 2010 L4H3 ex-Ambulance in to a camper. I’ve binned the old single DIN radio which was faulty and I’ve bought a F250 FL unit.
When I turn it on I get Welcome and then Code Error.
Is this unit now a pretty brick or can it be revived, please? Also, I guess I’ll need a code if it can be dragged back to life.
One other question. I’ve got a later VP2 ECE DAB NAV from a 2014. I know the connections are different so I’ve sourced a layer loom that I hope to splice in to the 2010 loom.
Am I being an idiot thinking about wiring the VP2 up or is there a chance in Hell I could get it to function?
Many thanks
DAVREN:
Could you help me with a code for my radio please, the unit I have isn't in the best condition but here are the details I've found:
815 BP 237233959372
FIAT MULTIPLA 7 642 372 316
021613
Thanks in anticipation
George
Hello guys, is the first time I hear about this radio blocking and my car is second hand so I don't have the code to unlock it (it's a fiat 500).
I managed to get the radio out to see the serial number, but it's a Mexican model so I'm not sure what is the serial.
I believe is this one:
TxxYD120310063
Could you please verify if you can get the code or inform me if I need to provide other numbers? Thank you so much!
TxxYD120310063
Sorry.... I don't have codes for any of the Mexican radios.
