The one and only code for fiat radio thread.
Hi Davren, I have donated in the past and you have given me a code for my Blaupunkt factory CD stereo. I have now purchased a used Blaupunkt either IDC or CDC A09 5 disc changer but there is no sticker on the unit and its asking for a code. From what I can tell it should be a Blaupunkt model 7 607 769 150 and the chassis stamped number is BP 915 014 263 958. Let me know if you can crack this and I will donate, thanks!!!:worship:(y)
The code for your IDC-A09 CD changer is: 1256
You do not need to donate again unless you really want to. (y)
Wow that was quick, thanks. (y)(y)(y)
I will try it tomorrow and post back.
The other code that you gave me when I donated I didn't have a need for anyways. When I switched out the battery on the car the radio kept working without asking for a code. I got the car without the code card so I think it was decoded by someone before I got it.
i tried that code and nothing happens
Just checked it again, 4151 is the correct code for the serial number you posted.
If the serial number you posted above is correct, then either the radio is not working or you are entering the code incorrectly.
Check the serial number and post it again if you've made a mistake.
The " WAIT " message is because someone has tried to enter to enter a wrong code too many times. You will need to leave the radio and ignition switched on for up to 2 hours until the display shows " CODE " then " _ _ _ _ " then immediately enter the correct code.
Hi there,
I have managed to retrieve the following codes off of the radio in my fiat ducato van..
Could you let me know if they will be enough to get me the code?
if so, i'll donate to the forum - could you send me a link??
Many Thanks
** CODES
BP331857
225721
Hi there,
Many Thanks
** CODES
BP331857
225721
The serial number should be stamped into the side of the radio.
If the serial number is BP331857225721 then I can get the code for it, but there should also be two 10 digit numbers starting with 7 on the radio label. There is a slight chance that I may also need those numbers.
https://www.fiatforum.com/donations.php
Hi there,
I have just made a donation to the forum - for some reason it has come up as anonymous, i hope you can tell that it was from me..?
If you wouldn't mind trying that first code that would be great and then let me know if you need the extra digits as its a nightmare to try and get that radio in/out!
Kind Regards
Thanks for donating to the forum.
Assuming you've posted the correct serial number.
Your code is: 1236
Hi, just tried that code and I'm afraid it hasn't worked - simply gone to 'wait'.. So I have re-checked the serial imprinted on the side of the radio and the one provided is correct..
Any ideas?
