The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
You don't need to have a Paypal account, just a card:
Hey guys, you are my last chance for setting my Blaupunkt radio on my recently new Fiat Punto MK2 2000. I already tried a few calculators, but only made it longer to wait. Donated to forum, please help me out:
BP9372X0839151
Fiat Punto LOW
7 649 372 316
Thanks a lot!
Thank you Davren for trying to help me, but this code is one that made my wait time from hour to two. Is there any other procedure, how to calculate the code? Or someone maybe changed the code? I assume that there is no other way to reveal the code. Thanks
Edit: just to make it clear. I waited for one hour, then wait changed to Code - _ _ _ _. I entered the code 5366 and then radio showed wait again. Is this procedure right? Or do I need switch it off and back on after waiting time and before entering the code.
You have used the correct procedure. It is possible, but unlikely that someone at a radio workshop has changed the code.
Check each number from the serial number in case one is not very clear. If there is any doubt what a number is, post the alternative and I will check for the code again.
I am afraid that the serial number is correct. I attached the image of the radio label, thank you for helping me, but I thing I am screwed.
You could try 7160 or 1160 but they are codes for a standard Blaupunkt radio with your serial number, not the special Fiat version. Because your part number ends with 316, it is the special Fiat version.
Hey,
I want also to donate to locate my PIN.
1. where do people find their serial number ? Which part / place in the car ?
2. I got for few months locked radio without a try to enter one - any idea what to do ?
thanks.
Thanks ! and do I solve the second problem ? I don't see "enter code" anymore - in the last months I get only radio block without the option to enter one.
Would you be able to help with a code? never had the radio working since the car was given to my girlfriend from her 90 year old neighbour 4 years ago. :doh:
Blaupunkt
BP237434034011
Fiat Punto CC
7642374316
Hi guys, can you help me to obtain the radio code for my Panda ?
Product code 7 648 730 516
Serial BP8730 B 1232001
Fiat nr. 7 354 949 830
Thanks in advance !
I have the code for you radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
