The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hi, I have just purchased a 2nd hand fiat punto and the radio says 'wait'. I have been advised to let engine and radio run for approx 2 hrs to allow the code to be put in. However I don't have a code either. The numbers I have for it are:
BP-NR7649372316
Prod No Fiat: 735289639
BP 93721566875
EI 021426
Donation made.
BP-NR7649372316
BP 93721566875
EI 021426
Donation made.
Thanks for donating to the forum. (y)
There is one digit missing from your serial number. It should be BP followed by 12 digits, not 11. Please check and repost the full number.
The waiting time to clear the "WAIT" message can be anything up to 24 hours depending on how many times incorrect codes have been tried. You don't need the engine running, just the radio and ignition switched on.
Hi there just changed alternator Ducato and dont have the radio code,
serial nubers from radio are as follows:
Fiat Ducato cc
7 643 319 316
Blaupunkt
815bp331954939403
Prod nr Fiat
735 407 007
if any one can help i would be greatfull, thanks
Hello Davren,
Thanks for the link and reply . The code numbers are 815 BP 829090820058
then on the right FIAT 312 SB05 S&S IVORY
7 648 290 316 THEN e1 034502.
Hope that's what you need .
I will go off to donate now !
All best
hello all,
i need a code for my fiat stilo radio,
its a :
visteon part number 7352969947, 2FCF-18C838-FA
model OB
SERIAL NO.
M005295
hope you can help me with this
Greeting's Matthijs
