The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Radio code for a scudo
i have a 2005 fiat scudo and after a flat battery i need the radio code to set the radio again.
I pulled the radio out to see the sticker and the numbers are as follow :-
pu_2294a(c)
9639219580
cl040140963709c
is it possible to get the code from this info if i make a donation ?
Thanks for your help and advice.
Regards
lanceb
Re: Radio code for a scudo
Sorry, this radio can't be decoded from the serial number.
It needs to be sent to a car radio engineer for an EPROM dump to get the code. Alternatively, providing it's the original radio fitted to the car, a Fiat dealer will be able to get the code from ISR. They will need the registration number and VIN and possibly sight of the registration document. Both methods will charge a fee.
Re: Radio code 1998 selecta punto 1.2
Hi all
How do i get this foc? I can get serial no and model no
If you post all the numbers on the back of the unit and make a donation to the forum then somebody (probably Davren) will no doubt have a looksee for your code then post it here :)
code for punto blaupunkt
numbers are as follows.
7649372316
735272569
and
BP9372Y3566029
thanks in advance
[edit]needs to use number 1-6 only, cheers
Yep may do if I can find label I had,the s no is on set but dont think rest are
and of course if its been re coded then code will be wrong.
Scudo radio reads end instead of code in
I have a fiat scudo taxi with a clarion radio fitted.
I just purchased a radio code for it online but I cannot enter it because instead of reading CODE IN it now reads END.
The drivers who use the vehicle have obviously been trying to crack the code, so is there any way I can get it back to asking for CODE IN ?
I have had the radio switched on for several hours but the END code remains on.
Thanks for any help.
