The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hello everyone,
i have lost me serial number of radio and i need some help.
My serial number is: M017320
Can u help me? thank you a lot.
Hello,
I am also looking for the code of my radio, although it isn't really clear what the serial number is. The make is grundig and the numbers are:
28178666
2990281786661918405710
7354812990
I will donate to the forum once you have replied if you could assist.
Thanks a lot
Hello,
28178666
7354812990
Thanks a lot
Sorry.... I don't have a calculator for Grundig radios. Most of them have to be decoded at a radio workshop.
Okay, do you think they would be able to do it at a fiat dealer?
If it's the original radio fitted in the car at the factory, a Fiat dealer should be able to get the code from the chassis number (VIN). They will probably need to see the registration document and some form of identity. They will probably make a charge for it.
Please,I need help for my Radio Visteon Fiat Stilo.
I need a code
Visteon
Fiat Part nr. 735296994
Serial nr. M010246
Model OA
Visteon part nr. 2FCF-18C838-AE
Thanks for help.
I need a code
Visteon
Serial nr. M010246
Model OA
Thanks for help.
My answer is the same as your 2 previous requests for radio codes.
I have the code for your radio.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Anyone help me i need the radio code for my fiat grande punto here is all the numbers on the side
Hi members,
I sure want donate if all the codes you members get work but theres still one problem.
We tried some codes found on internet but now we have to wait 24h till we can enter a new code. Is there anyway to speed up this?
Hi members,
You need to post all the numbers from the back and sides of the radio. Then I will let you know if I can get the code for you.
If you have tried wrong codes, you need to leave the radio and ignition switched on for up to 24 hours, depending on how many wrong codes you have tried.
Fit the radio back in the car, then connect a charger to the car's battery while waiting.
Or.... connect the radio to a 12 volt bench power supply. You would need to connect the negative side of the supply to the chassis of the radio, and the positive side to both the permanent, and ignition switched supply terminals on the radio.
