The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Re: Blaupunkt radio code
Im in need of my stereo code for my standard head unit, i have donated to the forum already. but i havent had my post answered to yet.
My codes are,
BP9372Y1172328
7649372316
Tim
Re: blaupunkt punto radio code
I have made a donation.............many thanks(y)
p.s. the display is currently showing WAIT is that because i used the wrong code and if so how can i get it to reset?:bang:
Thanks in advance(y)
when it says wait, just either wait a couple minutes or if your impatient then just disconnect the power and then re-connect it to enter your code again.
Re: Blaupunkt IDC A09 code help please
Have just given up!
The unlocking method of using the Visteon HU worked. On the Visteon the unit asked for the code which I entered. Then I plugged it into the Conect Nav unit, loaded some CDs, the unit went down the full 5 CDs span each one up, then popped it into park position. I hit the CDC button on the head unit. The first CD very briefly started to spin, then amessage saying NO CD. Nothing else happened. I reckon it was not only locked, but also knackered when I bought it!
Grrrrrrr!
Now on the look out for a new or definately working Blaupunkt IDC A09 unit!
Naffed right off. I bought the CDC from someone advertising it on this forum, described as in full working order and removed due to part exhange of the car it was in. In full working order my ring piece!
I am having what sounds like exactly the same problem as you have/had. I have been assured by the seller of my unit that it all works.
Is it possible you couls let me know how you have got the CN+ to request a code?
Thx
Radio unlock code - HELP!!!
Good afternoon, the children have just washed the car, left the radio on with the ignition key turned partly on, flat battery, jump started and hey presto the radio now needs a code which I haven't got! Can anyone help? The reference numbers on the Blaukpunt Radio/CD/SatNav are:
7 612 001 494
BP 149133522970
Thanks from a busy vicar!
Eoin :cry:
Re: Radio unlock code - HELP!!!
I can't find your part number anywhere. If it's the standard Punto RNS3 unit, the part number should be 7 612 001 433.
Please check this and post all the numbers from the back and sides of the unit.
I may be able to get the code for you.
give me the serial number (M.....) and I will tell you the code...
Yellowstilo
Hi mate
can you help with 1998 1.2 selecta on a philips rad/cass
model 22dc449/64L
other numbers on label are B112,Fiat 46517212,FD 0
97 45 4019475.
Cheers.
Numbers are correct. The model is a Travelpilot Fiat RNS4; Fiat product number 735337938. Other numbers are 021696 and S foloowed by 4303/F.
Thanks Eoin
Thanks Eoin
I'm not 100% sure on this one, never been asked for a RNS4 code before.
Try 3930.
Please let me know if this is correct for future reference.
I have sent back a stereo to be replaced and it's going to take a couple of weeks, so I've put the standard fiat radio back in but I need the code. Can anyone help.
Hi Ace
I am also needing one for my 1998 selecta how on earth do I post a question on these forums !!!
Re: Blaupunkt code
Hi Guys can anyone tell me my stereo code please
Serial number: BP915014276364
Part number: 7607769150
Model number: IDC A09 BP9150 CD-CHANGER
Thanks Gav​
