- Joined
- Dec 28, 2006
- Messages
- 377
- Points
- 118
Hi guys hoping you guys can confirm something for me. Took the panda out for a bit of a spin today as usually she only does small runs so never really gets that warm. Anyway after bombing along the mway for an hour I noticed the temp guage was only at 1/4 and interior not toasty warm even though heater set to max. Anyway came off of motorway to have a drive through a bit of nice country side. The cooling fans kicked in and engine management light came on with temp guage showing zero on meter. Pulled in at garage to check fluids and all was fine so have it 30 mins and a cuppa before setting off back and limped her back home( although was running fine tbh) just in case. Temp went back up to 1/4 and stayed like that all way home (70 + management light staying on) Plugged her into multiscan and it said water temp sensor. So cleared code. Engine management light now turned off. Left her ticking over on drive temp went up to half, so went for another short drive. Temp went down to 1/4 again. So put interior fan on 4 and temp went down to just above zero. Turned it off and it went back up to 1/4. Interested to see what you guys think. I am thinking stuck open thermostat. Shouldn't the stat regulate flow to keep the temp around half not 1/4? If so is it hard job to do?
