Technical Temp sensor / exterior mirrors / window - all dead!
Ironnike
I've been reading the forum for the last 5 hours and found many solutions but not exactly explained.Whats that a LATCH?first. I have problems with the central locking. Passenger side locks/unlocks only if i press twice the unlock button.Temp sensor and exterior mirrors are dead and i can't open any of the windows via driver side window panel.The lock/unlock button is dead too.The driver side lock works only with the key in the door. If any one can help is much appreciated.
i had the same problem with passenger door not unlocking untill double pressing the fob. All you have to do is go to the menu then select drvr lock then turn it off this basiclly enables you to open all doors from 1 press of the unlock button as when it is turned On only the driver door will open from 1 click.
Remove plug from door to base of 'A' pillar and then replace it into socket again. Should sort the connection out (y)
thanks for your answers lads. is sorted. i change'd the whole black box from the driver door now everithing works ok.
