That's it indeed ! It informs the Body Control Module (BCM) about the coolant temperature, the BCM then drives the radiator fan if necessary.
Regarding the "cable": ELM327 based BT plug and Torque Lite for Androïd should be way enough ...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
