M mypandapop New member Joined Jun 22, 2015 Messages 95 Points 30 Sep 17, 2015 #1 Hi, does anyone know where the sensor is for temp gauge? Mine is on about 80 when you put the ignition on, it does move as the car warms up but am not convinced with it. Cheers
firstcar-Y10 Busy breeding Pandas Parked in the garage Joined Jun 17, 2008 Messages 4,092 Points 1,074 Location Lincoln Sep 17, 2015 #2 Back of the head, above cylinder 1.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,383 Location Norwich, Norfolk Sep 17, 2015 #3 :yeahthat:
OP OP M mypandapop New member Joined Jun 22, 2015 Messages 95 Points 30 Sep 18, 2015 #4 Ok great, I thought that was just the overheat sensor. Will have a look or replace as temp gauge reads about 80 degrees when cold.
kolza Panda Wanda Parked in the garage Joined Feb 4, 2011 Messages 2,570 Points 811 Location YO11 Sep 18, 2015 #5 mypandapop said: Ok great, I thought that was just the overheat sensor. Will have a look or replace as temp gauge reads about 80 degrees when cold. Click to expand... Make sure the 6.3mm spade connector does have good contact, and same applies to good ground/earth to speedo cluster. Hedgehog connector job.
OP OP M mypandapop New member Joined Jun 22, 2015 Messages 95 Points 30 Sep 18, 2015 #6 kolza said: Make sure the 6.3mm spade connector does have good contact, and same applies to good ground/earth to speedo cluster. Hedgehog connector job. Click to expand... Wil do, job for the weekend!
