Technical  Water Temperature Gauge
turbo93
Hi all, after installing a new radiator, thermostat and water temperature sensor Im having a problem with the gauge as its not moving at all. It worked fine with the old sensor and now it doesnt move at all. Could it be the sensor is faulty? Or is there somewhere else i could look at? Thanks
Hi there
It feels very likely that the sensor is the culprit. Double check that the sensor part is the right one as perhaps you got a temperature switch rather then a sensor.
Hi there
Hi, i was told that the sensor that marks on the dash is in the engine block and i havent replaced that yet.
