Technical Temp Gauge
mypandapop
Hi, does anyone know where the sensor is for temp gauge? Mine is on about 80 when you put the ignition on, it does move as the car warms up but am not convinced with it. Cheers
Ok great, I thought that was just the overheat sensor. Will have a look or replace as temp gauge reads about 80 degrees when cold.
Make sure the 6.3mm spade connector does have good contact, and same applies to good ground/earth to speedo cluster. Hedgehog connector job.
