Technical  Techie Question
samuelbrr
Hello,
I have just bought my first brava for £995 at 76000 miles, just bought it about three/four days ago. Now since then I have needed a new starter motor £160.00 and since I didn't have a service history I got the cambelt and tensioners changes at £180.00. Picked the car up tonight and have been told that there is noise coming from the camshaft area (drivers side I think he said) and it requires further investigation.
This is an R reg 1.4 and wondered if anyone knew what this could be? I mean its booked in for a service on Wed 9th for spark plugs and further investigation. Am I looking at another high cost? or do you think I am worrying for nothing or should I get it look at like tommorrow?
-Samuel
I believe this is a common problem, caused by the cam followers (I think)
EDIT:
More info here
Hello,
Is it going to be expensive to sort and do you think its worth just getting it booked in tomorrow?
-Cheers
Samuel
Kev (bravo_owd_chap, my hubby and Bravo moderator) says if its been starved of oil or hasnt been serviced regularly then there is a pipe just above the cam shaft that lubricates the cam itself and these quite often get blocked, this in turn causes pre-cam wear on the bearings and can cause it to wear quicker and seize thus causing it to be an expensive repair :(
Hope this helps even though its not good news.
Let us know how you get on.
Hello,
Managed to get it in for the service tommorrow morning so I will know what is going on then, it sounds as though its gonna need a new cam shaft but what do I know.
Right now I have a figure in my head of how much I am willing to spend, £600 and no more so lets hope that is enough for any problems found.
Cheers!
-Samuel
Hello,
Thats good to hear :) as long as there is nothing else wrong! :( I have already paid like £360 on new starter motor and cambelt and tensioners.
Got the flu right now and just moved house on Satuarday and thats knocked the stuffing out of me so if I hear any really bad news you are sure to hear about a savage man with the flu wrecking local garage! :)
