Technical  worn camshaft and followers advice please!!
Garington
London E1
Hi, I'm a total novice mechanic and wondered if anyone could answer a few questions about problems I'm having with my 98 Bravo SX 1.4
It's got a worn camshaft and followers due to a block in the oil pipe to the cylinder head and I took it to a garage who said it would cost £650 to fix, probably because it would involve replacing the cam belt too. Does this sound like a reasonable price? are there any tried and trusted garages in London?
It's only done 100miles since I first noticed the problem (by the whining noise coming from under the hood) so, having changed the engine and filter oil and had an engine flush done, I'm wondering if I can get away with running it for a few hundred more miles before fixing without doing any further damage?
Also, would a camshaft and followers set for a Fiat Brava 1400 12v do as a replacement?
Any advice greatly appreciated!
G
if it does not sound in to much pain it will probs be ok 4 another few hundred miles,as long as that pipe is clear.old cavaliers i had always had knocking cams that went on 4 ever.but if it sounds like a bag of spanners dont risk it.keep the revs low.when you drive.
cheers, I'll shop around. That one on ebay's for a Brava, is it the same engine as the Bravo?
Cheers rich, it's just got a light knock at the moment so I guess I'll get the coupla hundred miles I need before I can get it sorted + it's had the pipe replaced and an engine oil flush so the blockage should've gone.
