D david goodwin New member Joined Jul 29, 2012 Messages 24 Points 7 Location lincolnshire Apr 2, 2013 #1 hi there all, How do you adjust the tappets on a 1999 fiat seicento sporting? Thanks DG
David C Patron member Joined Mar 29, 2005 Messages 1,787 Points 399 Location London Apr 2, 2013 #2 They don't "adjust", they are shims. So you measure clearance, measure existing shim, swap for appropriately sized shim, check clearance again.
OP OP D david goodwin New member Joined Jul 29, 2012 Messages 24 Points 7 Location lincolnshire Apr 2, 2013 #3 David C said: They don't "adjust", they are shims. So you measure clearance, measure existing shim, swap for appropriately sized shim, check clearance again. Click to expand... ok, will do... thank DG
OP OP D david goodwin New member Joined Jul 29, 2012 Messages 24 Points 7 Location lincolnshire Apr 2, 2013 #4 where can I get some new valve shimes from in Lincoln?
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,561 Location Liverpool Apr 2, 2013 #5 FIAT. But -- see your other post -- Fluffy will be cheaper.
