Technical tappets confused
allrightdrive
56 plate 1.4 petrol tappets knock when cold. it got a cam as apposed to rocker arm.but whats under it . lifters !! hy-tappet.!! or mechanical !!. HELP
It'll be an 8v with shim adjustable tappets. Adjusting them every ~36k miles is in the service schedule, don't know if anyone ever does.
Mine does the same from cold, buts its not noticeable when driving just a bit of noise on startup and it quietens down quickly and is fine when hot.
Hi, I have just bought a 56 plate 1.4 about 4 weeks ago and have only recently noticed the cold start tappet noise (I had the window down when starting and noticed the noise, which I hadn't heard before), but as you say the noise goes away when the engine has warmed up. Do you know if this is an expensive thing to rectify and /or does it cause any long term harm if not rectified? Does it also need to be a Fiat dealer who does the work?
