Hello Everyone..
Here Again..
replaced Bosch (Button primer type) with new one as suggested it could have diaphragm perished.. owing to can not get it primed because of air in system... the new one is just the same.. when trying to clear air out of fuel line from tank... it is still after a good squirt has air at at end of button push...
So in other words..
No fuel in line and starting is long turns of engine before it fires... the engine has done 33,ooo from new so in my opinion can only be the fuel pipe from the tank sender to the filter somewhere has a leak in it .. I have been under the floor carpet to check the sender and to see if there was obvious leaking as it smells of diesel when driving in the cab... But took pipes off.. and they are original so could have perished seals.. I had one once before that mice had been chomping on a line and did the same.. (could not build up pressure in tank to keep fuel in line for starting)...
So if anyone has had this problem ... maybe you could help to get right pipe as there are endless numbers of them to choose from...
Summary...
1).. Bosch filter new with Primer Button on top... (this is the old one in picture and was not that old )..
2).. The filter to tank pipe can only be the problem... as will not stop air in priming... as is the first means of getting fuel from tank...
3).. Rubber Seal on sender on tank are OK...
Lyn...
Here Again..
So in other words..
Summary...
Lyn...
