Technical tackling rust under car
i wonder what is the best way of tackling rust under car
My mk2 was Mot'd six months back,
floor was solid, straight pass on mot,
it was up on lift in garage the other day looking for a knocking noise on back wheel,
noticed hole in floor near sill, big enough to post a cig packet through, :eek:
so yeah they can rot in very little time,
its welded up now but will be getting painted up every 6mths or so underneath,
Here's a top tip with ramps. Drive the car up as normal. Jack the car off one ramp and turn it the other way round.
This is a damn sight safer than axle stands and you can get to where you are welding a lot easier.
When you cut a section out make a plate slightly bigger so you can lap weld inside first. Then lap weld underneath. You will find it a lot cleaner and quicker than trying to butt/seam weld wafer thin metal together.
anyone ever used Hammerite 'direct-to-rust' or similar stuff? got a nice layer of brown all over the underside of my Mk1 that i've been meaning to clean up for a while, hopefully delay the whole welding malarkey for a little while at least
