vasilGR
Good Evening! For months now I have been facing the following problem without anyone being able to find a solution: the car (FIAT Punto mk1 facelift 1.2 16v 86HP) while it drives normally, suddenly lose revs and shuts off and then does not start for a long time. The starter sounds but doesn't start the engine, or if it does, it shuts off immediately or after a few steps. After half an hour to an hour it works normally. The problem occurs suddenly about one time per month (after 2-3000 km). Moreover, the car even when it doesn't turn off, it's not performing well, I feel it kind of weak sometimes like it's going to turn off. Ι feel like Ι have to press the gas a lot harder to get it to go away.
I have changed these months: RPM sensor, fuel pump, spark plugs, spark plugs wires, fuel filter, oil, air filter, a central fuse and a main green relay (which powers the fuel pump) from the fuse box and some dry wiring. About 30 faults come out in diagnostics, we reset them and they come back. The faults concern the rev sensor, brain, low voltage battery and other sensors.
Any idea what it could be? We still don't know if it's an electrical or mechanical problem.
