Technical T-jet Rear lights not working
Butho
Hi my rear lights are dead.....that is the stop light and brake lights. I have changed the bulbs but they flicker on and then go off. It can't be the fuse as I have got a multimeter out next there clearly is power coming in. I got the bulbs from andrew page the 5w/21 as stated by manual please help. :bang::bang:
Check the contact leads on the plastic light bulb holder you extract from rear light (see picture). If you have power on contact leads (with lights turned on) then your problem is in contact between contact leads and light bulbs. Try fiddling with the contact leads to make sure they have proper contact with the bulbs. If you do not have power, the problem most probably is in wiring to the light or the contact between the light assembly and the connector that brings power to it.
