Yah... that is what i'm seeing. no fluctuation, no boost cut (can see that in throttle angle).
-Depending on the boost gauge sampling rate you might be loosing some data ...so the reason you're not seeing the same boost levels.
-The boost gauge might just not be very well calibrated.
Is the DeltaT in seconds? so 10-12 seconds to get full boost? that's not great, BUT depends at what rpm you start at. For example: if you start at 2000rpm, it will take much longer than if you start at 3000rpm.
-RPM and Vehicle Speed would help; So a few runs with what you have selected now, and a few with "Intake manifold pressure", "RPM" and "Vehicle speed".
I'd suspect the boost gauge/sensor: electrical connections (so worse when engine is bouncing about under load); or maybe it's just bad.
You could try fitting a restrictor in the hose to the sensor; the smaller hole will act like a capacitor on an electrical circuit.. it will smooth out the pressure to the sensor.
Was the gauge acting up while you were taking these graphs?
With regards to the boost gauge, it’s always worked spot on, it has a restrictor fitted, I’m guessing the sensor could be faulty and the full boost not registering correctly.
Ahh yes the readings were taken from 1000rpm to roughly 4000-4500 in 4th gear, that’s why there is so much lag.
I will (hopefully today) get a few more runs. The gauge was acting up during the runs, the needle was going up & down as previously described, I still need to show a video of this.
