Technical  Synthetic or semi?
Trekmac
Hi
Picking up a 2006 1.2 Panda next week. 89000 miles and I will change the oil and filter I probably use a Fiat filter but am unsure about whether to use semi or fully synthetic oil. What do people use?
Thanks for the replies. I think I'll get a semi such as Magnatec 10w40 with a Fiat filter and change every 6000ish. That is if I can get under the car without jacking it up as our driveway slopes. If not I'll get the garage to do it and supply the filter and maybe the oil too.
I may give that a try. The handbook I have downloaded said 10w40. I suppose it won't make much difference.
You should just be able to get under it on the ground, I do out of stubbornness of not being bothered to get it into the air :p :eek:
Haha - I jacked my 100hp up and spent ages underneath at the backend of the engine looking for a bright orange filter as big as a bean can.
If the filter is in the same position as the 100hp should be doable without jacking, though maybe just a bit to lift the body for some wriggle room.
A nice strap wrench needed, which even then is a tight fit.
on the 1.2 the sump plug is at the rear so jacking the front wheels off the ground will be more oil out.
TBH the front of the car being in the air or not will make negliable difference to the amount of oil that'll come out due to the location and angle of the drain plug being practically at the lowest edge anyway.
One could argue you'll get more oil out leaving it to drain for 12 hours over night as it all falls from the upper parts of the engine :p
... Or use a syphon pump made for the job.
Some will cry out in horror when they hear this, but I have been using such a pump for many years, and have saved all the hassle of hot oil on my hands, crawling about underneath, etc.
I get the engine hot, pump the oil out through the dipstick tube, fit new filter, and pour in new oil.
Ten minutes, clean and easy. No I'll-effects on engine.
Have several high-mileage cars, still running beautifully.
Doubts? Ask the Americans - they've been using this method for years.
Sweetsixteen.
And don't trust a simple jack alone....use some extra stands or something to secure the car when it's up..
:yeahthat:
Hydraulic jacks can and do fail!
Sweetsixteen.
Yet you still have to get a tub and oil into it when removing the oil filter? Or am I missing something :confused:
