Technical Swaybar hitting right side control arm
Eemnes
Hello all,
My car has been making a clunking noise from the front right (EU, passenger side) when going over sudden bumps like potholes or cobblestone streets. I've just had a look and found the recently replaced control arm has started showing some surface rust, it looks to be worse right below the swaybar. Any guesses?
Model
500 1.4 lounge
Year
2008
The rubber bushing here is a common failure, causing knocking.
I'd be surprised if it could hit the sway bar as a result, but there does look like signs of impact.
Test it by levering it with a bar to see if there's any free movement.
Well, it's been a while, but I finally got around to checking the control arm. The marked bearing was in awful condition and was replaced under warranty. Sadly, there is still a knocking sound from the front right end while making sharp left turns or going over cobblestone streets. Could this be a problem with the end links? What is the best way of replicating and diagnosing this noise with the car jacked up so I can have a look.
