Technical  Cruise control info
Edinburgh
Hey all,
So I know this is a reoccurring conversation but I’m looking into fitting oe cruise control into my obviously non ish compatible 2016 500s
What I know :
I have the wiring , tested it all and everything is present and pinned correctly.
ECU is looking for the signal through MES so I know that’s good.
TFT has now been changed to a known cruise control compatible version (once I get it working I’ll test the old one to see if it also work so I can help broaden the knowledge)
BCM part number starts with 520xxxxxx this is what I’m wanting to check out really, I know from my tinkering with vags it was well documented what BCMs worked with CC etc but not so much with Fiat stuff.
Could some of you with cruise control share the Fiat BCM code - will be the one starting with 52xxxxx
Yes I know a 3rd party cruise control unit is out there but reading reviews about its faults and not being able to find its type approval id rather stick with oe.
And yes I know I’d end up with less grey hairs just pxing this one in but there’s sentimental value with this car and I’ve spent the last few years keeping it as tidy as possible, plus the only car I’d go for is an 595/695 and this would be the same dilemma with those two.
Any help would be much appreciated.
Model
500s
Year
2016
I fitted an after market (AP900C) CC from Bridgewater Electronics to my 2022 595 - about £300 , works a treat and the stalk looks very at-home and not out of place at all , in or around the same place that the factory 500 goes (lower steering wheel cowl, just drill one hole)
I’ll keep that in mind , I’m currently at £150 spend and looking at the average BCM cost should be in that ball park , worst case scenario I sell the bits I’ve got together and get something like this eventually but for now I’m just wanting to figure it out. Dog with a bone and all that. Cheers tho.
Привіт усім,
Тож я знаю, що це повторювана розмова, але я розглядаю можливість встановлення оригінального круїз-контролю на мій, очевидно, не сумісний з 500-ми 2016 року випуску.
Що я знаю:
У мене є проводка, я її перевірив, і все на місці та підключено правильно.
ЕБУ шукає сигнал через MES, тому я знаю, що це добре.
TFT-дисплей тепер замінено на версію, сумісну з круїз-контролем (як тільки я його запущу, я перевірю старий, щоб побачити, чи він також працює, щоб розширити свої знання).
Номер деталі BCM починається з 520xxxxxx, саме це я й хочу перевірити. З мого досвіду роботи з вагонами було добре задокументовано, що BCM працюють з CC тощо, але не так сильно з Fiat.
Чи не могли б ви, власники круїз-контролю, поділитися кодом BCM Fiat? Він починатиметься з 52xxxxx.
Так, я знаю, що існує блок круїз-контролю стороннього виробника, але, читаючи відгуки про його недоліки та не маючи змоги знайти його схвалення типу, я б краще обрав оригінальний.
І так, я знаю, що в мене було б менше сивини, якби я просто зареєстрував це, але ця машина має сентиментальну цінність, і я провів останні кілька років, підтримуючи її в якомога більшому порядку, до того ж єдина машина, яку я б обрав, це 595/695, і з цими двома була б така ж дилема.
Будемо дуже вдячні за будь-яку допомогу.
Привіт усім,
Що я знаю:
