Hi guys, I had a bad knocking noise in the front suspension, after a closer inspection it turned out to be the ball joints, also the bushes were badly deteriorated. So I shopped around and the good people at LarkSpeed done me a good deal on most of the bits. It took me 9h to get it all sorted because the lower suspension arms I got had busted rubber covers and I had to swap them with the good ones from the used element. Also the back bushes were a bugger to remove, they wouldn’t even move without the help of mr. angle grinder
As the lower spring bed of the rear suspension arms is just bare metal it caused the paint on the springs to rub off and they corroded. I salvaged the old front top spring rubber mountings and after some adjustments with a stanley knife they turned out to be just right for the job, so now I hope the rear springs will live a bit longer
Prior to this Apex setup I had Bilstein B4 shocks and PI lowering springs, it was a good ride but the springs corroded and I couldn’t find other lowering ones that would go with the B4’s so I had to ride on standard springs :/ I’ve done 70k on the Bilsteins and to be honest there is still loads of life left in them! So they come highly recommended
Also as I have a s/s sports cat and complete PowerFlow exhaust system I’ve now put in a GreenStuff panel air filter and it seem to run quite nice, found it on eBay the other day
I took some photos during the entire operation so do have a look The car needs some time before the ride height comes down so I’ll take a photo then
