General Superspotter's Barchetta Project,well Doc's done it....
'erm, not seeing it on mine - where does it appear and what browser are you using? I am currently running firefox - wonder if its a IE issue...........?
It's a little stat under the avatar that says "Thanks: 0" (in my case anyway). I guess it's summat they've made so you can say cheers to people individually.
Definitely the same with both browsers - I'm on IE at work now, and Firefox at home
Must be hard finding friends when you drive something like this :p:D(y) ehhh
I noticed that "thanks" thing too. They were upgrading the forum software this morning so must be a new feature?
I just pressed it and.... "The following user says "Thank You!" to jiggy for this useful post:"
Here you go LRB, you will not get ripped off by Citroen again:mad:
Ignition off.
Press and hold the bottom left hand button on the display, I think it is the odometer button.
Ignition on and keep the button depressed for 10 seconds.
The display will read 0000 and the spanner light will go out.
Done.
And I will have another thank you thingy added:)
Ignition off.
Done.
Thank you, I followed the instructions and hey presto message has gone! Any idea how to re-set the ECU? In the past couple of days it has become sluggish in 2/3/4 gears, seems to be burning a lot of petrol and is smoky at startup - probably an oxygen sensor but I will start with re-setting the ECU (if I can)..........
