Technical sump removel 2009 punto abarth
fbikgb
Does anyone know how remove the sump it seems stuck on the clutch inspection plate its hanging off but can't detach from the clutch plate side have removed all visible bolts
Hi,and welcome to FF,
( general advice--as I've no idea what engine / spec you've got)
the sumps are generally sealed with a FIAT type of "mastic / sealant",
YES- it will feel "stuck-on", when changing rusted-out steel sumps,
the sump is often in pieces by the time the sealant "lets-go"..,
so if trying to remove a cast sump for internal mechanics.. be WARY,
Charlie
My car is a punto abarth 2009
Hi it's the 180 brake punto abarth essence 2009 the clutch plate looks attached to the sump
