i have a leak on sump, maybe two leaks
, on brava 1.6 elx 98..so i bought the sump gasket and i went to mine mechanic to change it, but he said that he is in big business so he cant help me right now..i am asking is it hard to change it by yourself..i was under the car and i saw some 20 or more bolts..that is not looking so hard to do..but i saw that two bolts are little harder to reach because of some metal part of suspension that is blocking it...does anyone have some experience with it, and is it hard to change it..is there any pattern to put the bolts back?
one more question..because i never solved the issue with mine car when on cold, mine revs are going up and down on their own when i press the pedal,and that results with gradually accelerating...there is some water going out of mine exhaust pipe..i know that is normal for some condensation to come out...but on mine when i rev it i leave the little paddle behind
..could this be in connection with that is mine car is drinking some water..just to remind you i had a head gasket changed...it is not takin so much water then that i left behind me..and sometimes emulsion comes back on oil pipe,and there is some condense on oil pipe cap,maybe sump is still dirty..but i changed the water and there are no traces of oil in the water...what this could be?
and finally
..sometimes i can smell the exhaust in the engine bay like something is in exhaust pipe..i was thinking to remove the catalysator, and to put regular pipe...
in mine country laws are not so hard
thanx!!!!!
and finally
thanx!!!!!
